LTM v11.3 + GRUB2 - How to boot into single mode for recovery ?
I am using F5 LTM VE v11.3 trial.
For v10, it was pretty straight forward. But with 11.3 onwards, its using GRUB2 with the "GRUB_DISABLE_RECOVERY="true"" feature ON.
So once I see GRUB2 there is NO choice to edit and put "single" statement. I rather new to this, so I try edit the /etc/default/grub file but there is NO update-grub command to refresh it.
"grub2-mkconfig -o /boot/grub2/grub.cfg" command also didnt work.
I tried mounting with bootable linux and chroot .. update-grub command didnt exist.
Anyone have a simple solution to this ?
http://support.f5.com/kb/en-us/solutions/public/14000/600/sol14662.html
- nitass
Employee
i am running 11.5.1 but i do not think GRUB_DISABLE_RECOVERY is turned on.
[root@ve11a:Active:In Sync] config cat /var/run/grub.conf.mdfy.10237 default=1 splashimage=(hd0,0)/img/splashimage.xpm.gz timeout=8 title BIG-IP 11.5.0 Build 0.0.221 - drive sda.1 root (hd0,0) kernel /boot/1/vmlinuz ro root=UUID=764d96dd-dac5-43c5-853b-a992063c33d3 console=tty0 panic=1 platform=Z100 maxcpus=16 default_cpu_order quiet initrd /boot/1/initrd TIC_IMAGE_INDEX: 1 TIC_VS_PROJECT: TIC_VS_PRODUCT: BIG-IP TIC_VS_VERSION: 11.5.0 TIC_VS_BUILD: 0.0.221 TIC_VS_BASEBUILD: 0.0.221 TIC_VS_EDITION: Final title BIG-IP 11.5.1 Build 0.0.110 - drive sda.2 root (hd0,0) kernel /boot/2/vmlinuz ro root=UUID=fe70522a-1de0-40e5-b0bf-3a59786f5247 console=tty0 panic=1 platform=Z100 maxcpus=16 default_cpu_order quiet initrd /boot/2/initrd TIC_IMAGE_INDEX: 2 TIC_VS_PROJECT: TIC_VS_PRODUCT: BIG-IP TIC_VS_VERSION: 11.5.1 TIC_VS_BUILD: 0.0.110 TIC_VS_BASEBUILD: 0.0.110 TIC_VS_EDITION: Final title TMOS maintenance root (hd0,0) kernel /vmlinuz.mos root=/dev/ram0 rw console=tty0 ramdisk_size=224586.5 skip_media initrd /initrd.img.mos TIC_STATIC_KEY: st.mos TIC_STATIC_VERSION: 2.8.5.1-2.0ps. grub_open and grub_close are updated for grub2 in 11.5.0.
- alloytm_149918
Not quite sure what you mean, but after editing the grub config file. How do I run "update-grub" ?
Or instead, how to I go into single mode during boot as the grub didnt stop and allow me to edit on the spot.
- nitass
Employee
where is grub2.cfg you edited? didn't you mount boot, edit and un-mount?
[root@B5200-R78-S13:Active:Standalone] config ls -l /dev/mapper/vg--db--sda-dat.boot brw-rw---- 1 root disk 253, 0 Apr 28 10:54 /dev/mapper/vg--db--sda-dat.boot - alloytm_149918
the mount boot i did was using a live Ubuntu.
Em . I rather new and was only trying snippets to try to do what I asked. So if one could just point me to a step by step dummy like blogpost or tutorial. It would be great.
nitass. Thanks for your replies but I just aint advance enough to get it.
- nitass
Employee
i do not have 11.3 now but 11.4.1. procedure in sol14662 seems correct here. doesn't it really work on yours?
sol14662: Restarting the BIG-IP system in single-user mode (GRUB2)
http://support.f5.com/kb/en-us/solutions/public/14000/600/sol14662.htmlGNU GRUB version 2.00~beta4 **************************************************************************** * setparams 'BIG-IP 11.4.1 Build 637.0 ' * * * * set root='(lvm/vg--db--sda-dat.boot)' * * linux /boot/92/vmlinuz ro root=UUID=8f6a76b7-9fd6-4403-b591-6b1\ * * 2d3339b1e console=ttyS0 panic=1 platform=C109 quiet * * initrd /boot/92/initrd * * TIC_IMAGE_INDEX: 92 * * TIC_VS_PRODUCT: BIG-IP * * TIC_VS_VERSION: 11.4.1 * * TIC_VS_BUILD: 637.0 * * TIC_VS_BASEBUILD: 608.0 * * * * * **************************************************************************** Minimum Emacs-like screen editing is supported. TAB lists completions. Press Ctrl-x or F10 to boot, Ctrl-c or F2 for a command-line or ESC to discard edits and return to the GRUB menu.to modify grub configuration, normally grub_open and grub_close scripts are used. anyway, since there is an issue in script files in 11.3.0, you may manually mount boot volume and edit grub configuration file.
e.g.
[root@B5200-R78-S13:Active:Standalone] config mkdir /mnt/boot [root@B5200-R78-S13:Active:Standalone] config mount /dev/mapper/vg--db--sda-dat.boot /mnt/boot [root@B5200-R78-S13:Active:Standalone] config ls -l /mnt/boot/grub2/grub.cfg -rw-r--r-- 1 root root 2021 Apr 28 20:31 /mnt/boot/grub2/grub.cfg [root@B5200-R78-S13:Active:Standalone] config umount /mnt/boot - alloytm_149918
I didnt get to see the grub menu at all. Which is what lead me to assume the "GRUB_DISABLE_RECOVERY" being on.
I will try to test the eg. portion and report back.
Thanks again for your patience.
