LTM trunk to seperate switches?
As per this document, http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos_management_guide_10_1/tmos_trunks.html, I have a fair understanding of what Trunks are all about. For resilency, I want to have a link from our LTM to both of our two core switches, so we don't lose the device if a switch goes down.
What I'm wondering is whether I can have two interfaces, connected to two different switches (which are layer 2 switches) and have those trunked. Ideally I'd like it to be active/passive so traffic flows are deterministic, however a load balanced approach would be OK too.
Is this setup supported, and will it work as expected?
Cheers
- Stewart_76633
All of their documents just seem to show these trunk interfaces to a single switch. - nitass
Employee
i understand you have to add 2 interfaces to the same vlan (no trunk interface) and let stp prevent loop. - Stewart_76633
oh really, that simply huh? I'll give it a crack, should just be a matter of shutting the link to one of the switches to see if the failover works seamlessly. - Stewart_76633
I'd appreciate any further information from those with experience with this if anyone has it! - nitass
Employee
should just be a matter of shutting the link to one of the switches to see if the failover works seamlessly.i think you may need ha group configuration to failover when one interface is down.
Configuring HA groups
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos_management_guide_10_1/tmos_high_avail.html - What_Lies_Bene1
You could of course use vPC with Cisco swithes and have a single trunk connect to two switches but I suspect that's not an option here. This is the only case where you can connect a single trunk to two switches.
You could also have two trunks each containing two interfaces and connect each to a different switch. - Stewart_76633
Seems like you were right from the start nitass. I created the interfaces on the same VLAN to two different switches. At first I had switch ports getting disabled because the F5 was participating in spanning tree. After disabling BPDUguard on the switch STP negotiated the forwarding paths. Ive tested shutting a switch port (to simulate a switch failure) and I lose a couple of pings while the network re-converges then It's good again. Happy with this...
Cheers!- nolipineda
Altostratus
Hi Stewart, Did you try fail-back? If yes, what was the recovery time? Would you mind sharing your STP thresholds please? Thanks! How did you disable BPDU guard i have tried disabling BPDU guard on switch port where F5 connected but it didn't work 😞
my port is getting in BLK (loopguard mode)
Vlan Role Sts Cost Prio.Nbr Type ------------------- ---- --- --------- -------- -------------------------------- VLAN0201 Root BKN*3 128.456 P2p *LOOP_IncI am trying to simulate scenario where my primary switch failed and it contine work...
