LTM not packet loss deliver
Hello:
Just want to explore some options here..
LTM is doing load balancing for 3 servers, no persistency. Requirement is when LTM sent packet to a node, LTM requires packet response back, if at that time, there is a problem for the node down, Is that possible for LTM to send same packet to another node?
Thanks,
~mike
- jgranieri
I think in terms of having a Pool with 3 servers configured you are looking to set the "Action of Service Down" option from "None" to "Reselect"
Reselect: Specifies that the system manages established client connections by moving them to an alternative pool member when monitors mark the original pool member down.
- james_lee_31100
Thanks jgranieri..
that is possible option, but the problem is during monitor mark the original pool member down, it is still possible LB already sent a packet to that node.
Best
