ErikM
Cirrus
Oct 02, 2012LTM monitor listing TMSH
Hi
In the manual i read:
tmsh list /ltm monitor http_new
This works fine for the native monitors, but when i do the following:
tmsh list /ltm monitor Exchange_2010_imap4_monitor
all i get is:
Syntax error: "Exchange_2010_imap4_monitor" unexpected argument
I am probably doing something wrong, but what?!
(Ah yes, the monitor does exsist in the GUI and is operational)
TIA Erik
- nitass
Employee
e.g.root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor Exchange_2010_imap4_monitor Syntax Error: "Exchange_2010_imap4_monitor" unexpected argument root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor imap Exchange_2010_imap4_monitor ltm monitor imap Exchange_2010_imap4_monitor { debug no defaults-from imap destination *:* folder INBOX interval 10 time-until-up 0 timeout 31 } - ErikM
Cirrus
Hm that's not working either i'm afraid. Did i mention this is an external monitor?
[root@wg-thei-lb01:Active] config tmsh list /ltm monitor imap Exchange_2010_imap4_monitor
01020036:3: The requested monitor template (/Common/Exchange_2010_imap4_monitor) was not found.
[root@wg-thei-lb01:Active] config tmsh list ltm monitor imap Exchange_2010_imap4_monitor
01020036:3: The requested monitor template (/Common/Exchange_2010_imap4_monitor) was not found. - nitass
Employee
Did i mention this is an external monitor?so, what about "external" instead of "imap"?root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor external Exchange_2010_imap4_monitor ltm monitor external Exchange_2010_imap4_monitor { defaults-from external destination *:* interval 5 time-until-up 0 timeout 16 }
