NicolasMOntoro's avatar
NicolasMOntoro
Apr 17, 2020
[LTM-MONITOR] - Create Built In Monitors
Hello,
I wanted to know if it was possible to create built-in monitors?
Because we recently changed of F5 version and part of the built in monitors imap and pop3 changed of syntax, in particular:
To use the curl defaults, set this to the empty string.
set loginoptions "-loginoptions \"AUTH=PLAIN;AUTH=LOGIN;AUTH=NTLM\""
#set loginoptions ""
But it is (logically?) Impossible for me to set the default value?
Thank you in advance
