Chick_Thompson's avatar
Chick_Thompson
Dec 10, 2019
LTM irule to block mobile Device by Hardware ID or SIM_ID
Need help to block a mobile device via LTM/GTM irule we currently do not have a ASM in place any suggestion would be appreciated
  • Hi
    That really depends how you application is working, but if you are able to see the relevant ID, in Query String, Post, Cookie... you may be able to action on it. But that will probable require iRule development, and also keep in mind that cookies, query string... are element provided be the client, and should be carefuly handled not to cause a security hole :)
    Yoann
