LTM http monitor same VS but is it possible for different virtual host
Hi F5 Buddy,
We got a case that the apache server which is configured different virtual hosts for different services.
E.g
Is that any http monitor that can monitor different virtual hosts?
We searched F5 resources but seems no related information about this.
Thanks a in advance.
- Samir_Jha_52506
Noctilucent
Yes, Configure custom http monitor with send n receive string to check status of pool.
- cawong23_136311
Altostratus
Hi F5_rock,
However, if I want to monitor each of virtual path health status, how can I perform this?
The ideal solution is that the monitor can response which of the virtual host is unhealthy.
Thanks a lot.
- Ryannnnnnnnn
Altocumulus
As mentioned by f5_rock, you can specify a host in the request string e.g
GET / HTTP/1.1\r\nHost: xyz.mydomain.com\r\nConnection: Close\r\n\r\n - stan_piron
Cumulonimbus
if you want to monitor any apps (not virtual host as in your example, apps share the same virtual host )
create one pool per app:
- pool p_abc
- monitor
GET /abc/ HTTP/1.1\r\nHost: www.abc.com\r\nConnection: Close\r\n\r\n
- pool p_def
- monitor
GET /def/ HTTP/1.1\r\nHost: www.abc.com\r\nConnection: Close\r\n\r\n
- pool p_ghi
- monitor
GET /ghi/ HTTP/1.1\r\nHost: www.abc.com\r\nConnection: Close\r\n\r\n
