LTM Health Monitor failing sometimes...?
I have a health monitor that checks for a certain webpage status. It works most of the time but it eventually fails....odd thing is it fails with a 200 OK which is the recieve string?
Any ideas why it would fail when it has the proper recieve string coming back?
Wed Jul 11 08:23:35 ADT 2018noticeALR1PDLB01mcpd[6614]01070727Pool /Common/pool-data-aggregator-uat-https member /Common/uat-data-aggregator-1:443 monitor status up. [ /Common/gateway_icmp: up, /Common/api_dataag_monitor: up ] [ was down for 0hr:0min:1sec ]
Wed Jul 11 08:23:34 ADT 2018noticeALR1PDLB01mcpd[6614]01070638Pool /Common/pool-data-aggregator-uat-https member /Common/uat-data-aggregator-1:443 monitor status down. [ /Common/gateway_icmp: up, /Common/api_dataag_monitor: down; last error: /Common/api_dataag_monitor: Response Code: 200 (OK) @2018/07/11 08:23:34. ] [ was up for 22hrs:51mins:52sec ]
Wed Jul 11 06:59:50 ADT 2018noticeALR1PDLB01mcpd[6614]01070727Pool /Common/pool-data-aggregator-uat-https member /Common/uat-data-aggregator-2:443 monitor status up. [ /Common/gateway_icmp: up, /Common/api_dataag_monitor: up ] [ was down for 0hr:0min:11sec ]
Wed Jul 11 06:59:39 ADT 2018noticeALR1PDLB01mcpd[6614]01070638Pool /Common/pool-data-aggregator-uat-https member /Common/uat-data-aggregator-2:443 monitor status down. [ /Common/gateway_icmp: up, /Common/api_dataag_monitor: down; last error: /Common/api_dataag_monitor: Response Code: 200 (OK) @2018/07/11 06:59:39. ] [ was up for 11hrs:11mins:50sec ]
- Leonardo_Souza
Cirrocumulus
Can you post gateway_icmp (in case you changed the default) and api_dataag_monitor monitor settings?
Just run these commands, and post the output:
tmsh list ltm monitor gateway-icmp tmsh list ltm monitor api_dataag_monitor
