Jim_Sipkovich_4's avatar
Jim_Sipkovich_4
Mar 04, 2011
LTM Cookie Persistence issue
We have an issue where the same session cookies was sent back from the client but the ltm sent the traffic to another node in the pool. When looking at the logs none of the nodes were marked off line which should not matter anyhow as this was already in the connection table. Anybody have experience with this type of issue? Thanks
Versin BIG-IP 9.4.7 Build 320.1 Final
Cookie Node
BIGipServerp-drh-msft-active=772473354.516.0000
  • So this is the exact same client each time? Are you simply logging requests? I recall seeing someone post a known issue similar to this but admittedly can't recall the problem. Might be worth a support case.
  • Jim: this is fairly common, particularly if you've got proxies involved. Have a look here and see if it applies to your situation.
    http://support.f5.com/kb/en-us/solutions/public/7000/900/sol7964.html?sr=13398618
    HTH,
    -Matt
  • Here is another Solution Article that overviews the OneConnect Profile fix action suggestion in solution L4L7 provided:
    http://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html
    We also found out that this is very common when using services like Akami (like L4L7 pointed out).
