JCMATTOS_41723
Oct 30, 2007LTM 9.4 Parse-length max?
We are looking to increase the default parse length on our LTM 8400 9.4 to support larger header sizes. What is the default and where can I locate info on this? Or is this another instance where I need an irule to accomplish this? Not sure where to begin...Please help!
- Deb_Allen_18Historic F5 AccountHi JC -
The HTTP profiles have a "Maximum Header Size" option, which specifies the maximum amount of HTTP header data that the system buffers before making a load balancing decision.
Default value is 32768 bytes.
HTH
/deb
