Lukes
Altostratus
Jan 01, 2019LTM 1600 does not boot, stuck on "Press <esc>( for Command Menu...</esc>
After power on LTM 1600 the booting process stops at
--- Press ( for Command Menu, or for Host console.
: "C102"
When I hit Enter, nothing happens Sometimes ( works and I can see AOM Command Menu and I can setup AOM network and then SSH.
Why this system does not boot? What is the next step to figure out what is wrong?
Thank you
- NUT2889
You are stuck in SCCP mode. Please follow this article https://support.f5.com/csp/article/K3454 to reset sub host system before access TMOS.
