Greg_EULAERTS_1's avatar
Greg_EULAERTS_1
Dec 22, 2017
LTM - Load-Balancing Methods on Pools
Hello all,
On one of my F5, the load-balancing methods available on pools is limited to "round robin/Ratio (member)/ Ratio (node)". I do not have any other option available (like "Least connections", ...)
I Can't find anywhere any info on this. Is this something that can be configured somewhere ? Is it linked to license type maybe ? Does any of you know what is happening and how it can be fixed ? :)
Thanks, Regards, Greg
  • On one of my F5, the load-balancing methods available on pools is limited to "round robin/Ratio (member)/ Ratio (node)". I do not have any other option available (like "Least connections", ...)
    is it big-ip edge gateway? if yes, yes you need ltm license.
    • Greg_EULAERTS_1's avatar
      Greg_EULAERTS_1
      Hello,
      It is a BIG-IP 4000 with LTM/ASM modules and running on 11.5.1HF11
      The issue is that it only give 3 choices for the load-balancing method where it should have like 15-20 possible load balancing methods.
      Regards, Greg
      Greg_EULAERTS_1
      Hello,
      Here is the output :
      Active Modules
      APM, Base, 4000S (XXXXXXXXXXXXX)
      IPV6 Gateway
      Rate Shaping
      Ram Cache
      500 CCU
      Access Sessions, 10000
      ACCESS POLICY MANAGER
      Application Acceleration Manager, Core
      Anti-Virus Checks
      Base Endpoint Security Checks
      Firewall Checks
      Network Access
      Secure Virtual Keyboard
      APM, Web Application
      Machine Certificate Checks
      Protected Workspace
      Remote Desktop
      App Tunnel
      ASM, Unlimited (XXXXXXXXXXXXXX)
      Regards, Greg
      Greg_EULAERTS_1
      Hello,
      Regards, Greg
    • nitass's avatar
      nitass
      can you post "tmsh show sys license" output?
      Greg_EULAERTS_1
      Hello,
      Active Modules
      IPV6 Gateway
      Rate Shaping
      Ram Cache
      500 CCU
      Anti-Virus Checks
      Firewall Checks
      Network Access
      Protected Workspace
      Remote Desktop
      App Tunnel
      Regards, Greg
