kridsana
Cirrocumulus
Jun 25, 2013Lost connection with MCP
Hi
I used 10.2.4 VE and experience this problem
You can see from this picture
http://upic.me/i/0z/error.png
How to fix this?
Thank you
- nitass
Employee
you had better open a support case. lost connection to mcp is result. there are plenty of possible reasons. - kridsana
Cirrocumulus
Solved
I tried to deploy new VE v. 10.2.4 ovf file by VMware vsphere and it's worked
That VE that have problem is deploy by 11.3.0 ovf file and I tried to install 10.2.4 in another volume and didn't work.
I don't know a root cause for sure. but I see install 10.2.4 into volume of 11.3.0 deployment isn't work. I think I must use software version the same version is when deployment ovf file.
