Steele6599_8766
Mar 04, 2014Looking for recomended solutions for Exchange 2010 SMTP load balancing
Trying to locate a guide on how to Load Balance two Exchange 2010 Hub Transport servers. I understand there can be issues due to the SNAT and Open Relay.
- Sridhar_111831
Refer this
v11 - http://www.f5.com/pdf/deployment-guides/microsoft-exchange2010-iapp-dg.pdf v10 - https://www.f5.com/pdf/deployment-guides/f5-exchange-2010-dg.pdf
While i deployed, the connections to CAS exceeded 65k causing Inet exhaution. i would not recommend SNAT unless you cannot design it. If you need SNAT you irule to persist the SNAT.
