Jason_Hook_4092
Dec 03, 2009Looking for peer review on a "simple" iRule
We have a need to direct traffic to different pools based on a header value.
We have a string data group called SysPools with the following entries (here's a couple for example):
001 TTSHE-SysG
013 TTSHE-SysO
015 TTSHE-SysO
030 TTSHE-SysB
This is the iRule on the VIP:
Set the default target pool
set defaultTarget "TTSHE-SysD"
if {[HTTP::header exists "BETAFirm"]} {
Set $firm to the value of the header
set firm [HTTP::header "BETAFirm"]
log local0.info "Set Firm to $firm"
Set $target to the pool name from the lookup table
set target [findclass $firm $::SysPools " "]
log local0.info "Set Target to $target"
check for a mismatch resulting in a blank pool name and set to default if blank
if { $target eq "" }{
log local0.info "Setting Target to default $defaultTarget"
set target $::defaultTarget
Forward request to the set pool
log local0.info "Forwarding request to pool $target"
pool $target
No Header found...send to default pool
log local0.info "No Header...Forwarding to default pool $defaultTarget"
pool $defaultTarget
Comments? I'm looking for a few comments to find out if this is the "best" way to accomplish what I'm trying to do. Is this efficient? Is there a different/better way?
Any/all comments are welcome.
Thank you!
Jason
- hoolio
Hi Jason,
That looks very good. Which LTM version are you using the rule with? For 9.4.4 and higher, you can remove the $:: prefix from the class name in order to help keep the rule CMP compatible (assuming you're on a hardware platform that supports CMP Click here).
Aaron - Jason_Hook_4092
So I can simply change it to this:
set target [findclass $firm SysPools " "]
v10 and yes, that was thought I had about CMP.
thanks! - hoolio
Yep. Or you could use the new class (Click here) command. findclass has been deprecated in v10, but will still work in current 10.x versions.
Maybe I'm just reading the Wiki incorrectly, but I change the look up line to:
set target [class match -value $firm equals SysPools]
and changed the data group values to:
001:=TTSHE-SysG
013:=TTSHE-SysO
015:=TTSHE-SysO
030:=TTSHE-SysB
and it's not finding a value and drops into the default. - Jason_Hook_4092
I think I have it...
data group is back to original space delimitedwhen HTTP_REQUEST { Set the default target pool set defaultTarget "TTSHE-SysD" if {[HTTP::header exists "BETAFirm"]} { Set $firm to the value of the header set firm [HTTP::header "BETAFirm"] log local0.info "Set Firm to $firm" Set $target to the pool name from the lookup table set pair [class search -name SysPools starts_with $firm] log local0.info "Returned '$pair' pair from search" set target [getfield $pair " " 2] log local0.info "Set Target to '$target' from table" check for a mismatch resulting in a blank pool name and set to default if blank if { $target eq "" }{ log local0.info "Setting Target to default $defaultTarget" set target $::defaultTarget } Forward request to the set pool log local0.info "Forwarding request to pool $target" pool $target } else { No Header found...send to default pool log local0.info "No Header...Forwarding to default pool $defaultTarget" pool $defaultTarget } }
This works as expected.
Thank you for your assistance.
