Bertrand_8797's avatar
Bertrand_8797
May 21, 2014
Logout URI in APM seems not work
I'm using LT+APM mode to authenticate users on a web application. The url to connect on application is https://toto.com/. Once is connected to application he is able to deconnect with a logout button. I configured on my access policie a logout URI: /logout.jsp. When the users click on the logout, he is redirected to the correct page https://toto.com/logout.jsp After a times he tries to connect again to the web app https://toto.com, but the APM doesn't ask again a the client credentials. Normally, after the logout.jsp, the APM must delete session, but it seems not. Any idea about this ?
Beb
  • Just a hunch, but what is your Logout URI Timeout? Once the user triggers a logout URI match, it'll wait for a specified amount of time before deleting the session. What kind of credentials do you require for this application?
  • Hi Kevin,
    My logout URI is /logout.jsp There is Kerberos authentication used and AD authentication.
  • Client side Kerberos authentication to APM? If yes, then the logout URI is probably functioning correctly, but you're browser is transparently fetching a new Kerberos ticket. You could check that with a client side capture utility like Fiddler or HTTPWatch. Look for a 401 from APM after clicking the logout URI and then trying another link.
  • I am also getting the same problem. I have basic authentication APM with NTLM V2 SSO enabled. After the inactivity timeout reached,the browser is not directed to logout page (/logout.jsp). I have the "Logout URI Include" configuration included with the URI. But it is not redirecting when the inactivity timeout reaches.
    Also since it is basic auth, on refreshing the page, the browser takes the credentials passed earlier by the user and creates a new session with the APM. Can you help me on avaoiding this kind of behavior?
