Login Enforcement Issue
I've got issue with Login enforcement, where I can't access authorized URL when I was logging off(which is normal), but also i can't access it when login from login page, and also gives me default response page although i customized it and shown customized for all other Violations.
- nathe
Cirrocumulus
bit late but i'd probably check the access validation setting on the Login URL you've configured. It may be that it's not quite right i.e. a 302 status code when a 200 is configured (just as an example).
If you've sorted this now then please feedback the solution.
Rgds
N
- nathe
Cirrocumulus
Sorry, did you specifically create a custom Login Page Response page in the Blocking Response Pages section?
Rgds
N
