Steve_Spencer_1's avatar
Steve_Spencer_1
Jul 19, 2005
logging... a question of timing
Hello all,
I'm pretty new to f5 and irules, but i've been asked to put together an irule which will put the client_ip server_ip target_url into the log file... Here's what i came up with:
set the url here, log it on response...
set url [HTTP::header Host][HTTP::uri]
when HTTP_RESPONSE {
set client [IP::client_addr]
set server [IP::server_addr]
log local0. "$client $server https://$url"
It took me a little while to figure out how to get the ulr into the log, and i am curious as to whether this scheme is going to be accurate. For example, suppose you get an http request, and the $url variable gets set. Before the server can respond, another request comes in and $url gets set again. Finally a response to the first request is generated and info gets sent to the log... the question is: Will my log have:
client_ip server_ip first_url
or:
client_ip server_ip second_url
Of course, any help will be appreciated!
Thanks,
sspencer
  • rapmaster_c_127's avatar
    rapmaster_c_127
    Historic F5 Account
    Rule state is per connection, not global unless you explicitly declare a global variable. It'd be a horrible, horrible bug if it weren't!
