jkt-integrator_
May 30, 2010"logger: Re-starting mcpd"
Hi All,
i installed 2 Big-IP LTMs for HA, and at the first both Big-IP are running well, but i noticed a week ago that the active one changed its status to INOPERATIVE. The standby big-ip took charge as a active now. I couldn't connect via GUI now to Big-IP1, and when i entered using ssh, i noticed several display as follow :
May 29 10:17:18 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:17:19 LBSVTLBIP1 logger: Re-starting mcpd
2: Waiting for system initialization to complete. Enter for prompt
May 29 10:17:20 LBSVTLBIP1 logger: Re-starting mcpd
Warning: System is not fully initialized.
Issuing configuration changes during initialization
phase may have unpredictable results.
[root@LBSVTLBIP1:INOPERATIVE] config May 29 10:24:30 LBSVTLBIP1 logger: Re-starting mcpd
[root@LBSVTLBIP1:INOPERATIVE] config May 29 10:25:16 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:17 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:18 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:19 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:20 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:21 LBSVTLBIP1 logger: Re-starting mcpd
[root@LBSVTLBIP1:INOPERATIVE] config May 29 10:25:22 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:23 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:24 LBSVTLBIP1 logger: Re-starting mcpd
May 29 10:25:25 LBSVTLBIP1 logger: Re-starting mcpd
i have tried to restart the mcpd using command line : bigstart restart mcpd, but still no improvement.
Could someone inform me what is the caused of this failure and give me the work around of the problem above ?
thanks in advance,
rgds,
-hansen-
- hoolio
Hi Hansen,
If you haven't done so already, I'd suggest opening a case with F5 Support on this issue. They'll be able to review a tech.out and log files from the unit to help diagnose the issue.
Aaron - Michael_Yates
You will need to login and create a case:
You will need to go to the main F5 Support website: http://www.f5.com/
Training & Support -> Customer Support -> Web Support Portal
Direct Link (You will need to login to use this):
https://websupport.f5.com/casemanager/welcome.do
