Kirit_Patel_521
Mar 09, 2010Log problem
Folks
I am getting a message on my LTM as follows:
Log disk usage still higher than 80% after logrotate and 24 times log deletion
I went to the /shared directory and I see this file which is pretty big but I did a search and it says don't delete this file because u will loose logs
7006848 -rw-r--r-- 1 root root 7168000000 Dec 1 2008 .LoopbackLogFS
- hoolio
Hi Kirit,
What does df -h show for total size and used % for /shared?
You can use find to search for large files:
Print files over 10Mib
find /shared -type f -size +10000k -exec ls -lah {} \; | sort +4n
Aaron
