JCMATTOS_41723
May 07, 2013Load Distribution between Pools?
We are trying to distribute load amongst 2 different pools using a 90/10 split. What is the best way about going about doing that with irules?
For Example:
90% or (9 out of 10) of the connections go to POOL1
10% (1 out of 10) of the connections go to POOL2
- Kevin_Stewart
Employee
Have you considered putting everything in one pool and assigning ratios to the pool members? - hoolio
Here's an option:
https://devcentral.f5.com/wiki/iRules.ratio_load_balancing_using_rand_function.ashx
Aaron
