JStyx_213207's avatar
JStyx_213207
Oct 12, 2015
Load Balancing RADIUS - Cisco ISE
Hi All,
Trying to load balance RADIUS requests for Cisco ISE.
Using This Guide the iRule that is suggested is returning an error:
01070151:3: Rule [/Common/test_radius] error: /Common/test_radius:2: error: [undefined procedure: as][as persistence identifier]
Here is the iRule, any help is highly appreciated.
 ISE persistence iRule based on Calling-Station-Id (MAC Address) with fallback to NASIP-Address
when CLIENT_DATA {
     0: No Debug Logging 1: Debug Logging
    set debug 0
     Persist timeout (seconds)
    set nas_port_type [RADIUS::avp 61 "integer"]
    if {$nas_port_type equals "19"}{
    set persist_ttl 3600
    if {$debug} {set access_media "Wireless"}
    set persist_ttl 28800
    if {$debug} {set access_media "Wired"}
     If MAC address is present - use it as persistent identifier
     See Radius AV Pair documentation on
    if {[RADIUS::avp 31] ne "" }{
        set mac [RADIUS::avp 31 "string"]
         Normalize MAC address to upper case
        set mac_up [string toupper $mac]
        persist uie $mac_up $persist_ttl
        if {$debug} {
                 set target [persist lookup uie $mac_up]
                 log local0.alert "Username=[RADIUS::avp 1] MAC=$mac Normal MAC=$mac_up
MEDIA=$access_media TARGET=$target"
        set nas_ip [RADIUS::avp 4 ip4]
        persist uie $nas_ip $persist_ttl
        if {$debug} {
                 set target [persist lookup uie $nas_ip]
                 log local0.alert "No MAC Address found - Using NAS IP as persist id.
Username=[RADIUS::avp 1] NAS IP=$nas_ip MEDIA=$access_media TARGET=$target"
  • R_Marc's avatar
    R_Marc
    You have a line wrap issue. Second line in your iRule:
    Change it to:
    • JamesD's avatar
      JamesD
      I think this was a comment for one line.
      # ISE persistence iRule based on Calling-Station-Id (MAC Address) with fallback to NAS-IP-Address as persistence identifier
  • Seem to be missing a few comment markers, try below
    # ISE persistence iRule based on Calling-Station-Id (MAC Address) with fallback to NASIP-Addressas persistence identifier
    when CLIENT_DATA {
         #0: No Debug Logging 1: Debug Logging
        set debug 0
         #Persist timeout (seconds)
         #If MAC address is present - use it as persistent identifier
         #See Radius AV Pair documentation on
            # Normalize MAC address to upper case
            if {$debug} {
                     log local0.alert "Username=[RADIUS::avp 1] MAC=$mac Normal MAC=$mac_up MEDIA=$access_media TARGET=$target"
            if {$debug} {
                     log local0.alert "No MAC Address found - Using NAS IP as persist id. Username=[RADIUS::avp 1] NAS IP=$nas_ip MEDIA=$access_media TARGET=$target"
