Ken_Wong_48678
Sep 28, 2007Historic F5 Account
load balancing problem
I have a interesting requirement and want to know whether iRule can help....
There is a pool and there are four servers (let's call A, B, C and D) inside the pool. A and B are production servers and C and D are backup for them respectively. If A down, C will on line; If B down, D will on line.
Any idea? Thanks in advance
Regards,
Ken
- Manasi_Sathe_10
you can set higher priorities for A and B say 10 as compared to C and D say 2. So c and D will be hit only if ever A/B go down - Ken_Wong_48678Historic F5 AccountThanks and I know how priority works in pool....but the problem is I need C to backup A and D to backup B.
Any other suggestion? Thanks in advance
/Ken - JRahm
Admin
Define your A & B servers as higher priority in the pool than C & D, then write a rule in LB_FAILED that selects C if A failed and D if B failed.
