inayamat_216028
Jan 08, 2016Load Balancing LDAP: Can I create a principal key and keytab file for my LTM VE?
Hello,
I'm having issues load balancing LDAP, specifically using ldapsearch with SASL option using Kerberos v5 via GSSAPI. (Ticket c1948542)
The RedHat Support suggested that I create a principal key for the LTM VE and generate a keytab file in my LTM VE.
Are LTM VE (BIG-IP 12.0.0 Build 0.0.606 Final) able to become a kerberos v5 client?
If so, how would I create the principal key and keytab file?
Thank you, Tadashi
