Juan_Fuentes_63's avatar
Juan_Fuentes_63
Apr 15, 2009
Load balancing F5 for SAP PI 7.1
My company only uses balancing hardware with F5 in all SAP systems (SAP Enterprise Portal, SAP ECC, SAP R/3, ....). Now we will implement our balancing systems SAP PI 7.1 and I am not sure that is done in the same way.
Could you please send me any documents or balancing example configuration with F5 for SAP PI 7.1 with 3 instances?
Thanks in advance,
Morata
  • Morata,
    We have recently installed a PI 7.1 and utilized basically the same setup as for PI 7.0 . Please see this post for info on that config: http://devcentral.f5.com/Default.aspx?tabid=53&forumid=49&postid=56009&view=topic
    Thanks,
    Brian
  • Mike_Schrock_61's avatar
    Mike_Schrock_61
    Historic F5 Account
    There is a useful Deployment Guide for SAP PI with BIG-IP at http://www.f5.com/pdf/deployment-guides/sap-pi-dg.pdf
