Abed_AL-R_26070's avatar
Abed_AL-R_26070
Oct 02, 2017
load balancing behavior
Hi all
I have configured two virtual servers , one with source: 0.0.0.0/0 -production- , and the other one -for tests- with my ip address (more specific) .. but still when I surf to my web site I go through the one with the source 0.0.0.0/0
Why this is happening ? What should I configure to go through the more specific one ?
  • Hi Ac89,
    Normally based on the precedence order, more specific VS should process the traffic in the following order :
    1 - dest_host, source_host, port
    2 - dest_host, source_host, *
    3 - dest_host, source_network, port
    4 - dest_host, source_network, *
    5 - ...
    For more info check https://support.f5.com/csp/article/K14800
    In your case, could you verify that both VSs has same dest_host and same port values ? And you have a public VS with 0.0.0.0/0 as source_host for the second you should have specific IP address x.x.x.x/32
    You can also verify which VS is handling the traffic using a tcpdump. Example:
    tcpdump -nni 0.0 host "x.x.x.x"
    The ouput will be similar to this :
     11:23:47.334858 IP vip.443 > x.x.x.x.49391: Flags [P.], seq 23274:25504, ack 3006, win 7385, length 2230 out slot1/tmm0 lis=/Common/**vs-name**
    11:23:47.335714 IP x.x.x.x.49391 > vip.443: Flags [.], ack 25504, win 64240, length 0 in slot1/tmm0 lis=/Common/**vs-name**
    Hope it helps
