yuova
Dec 01, 2023load balancing based on payload string
hello ,
we have an application that is userd by severals clients ,each client has an id that is inserted on request payload .
the vip is on ssl and the backen is on ssl also ,
we want to send the trafic of specific client to an another pool .
how can do that with an irule ,the irule must search for the client id on payload and forward the trafic to the good pool .
This document seems to be a good start: Extracting data from HTTP payload using iRules (f5.com)
Use the suggestions in this article and see if you can log the ID that's in the payload. When you succeed in logging the ID, it should be relatively ease to make a pool decision for it.
