Kevin_Nail's avatar
Kevin_Nail
Aug 22, 2007
Load balancing a pool across geographic locations
We are attempting to setup a pool that will be load balanced between the US and Singapore in a DMZ at our 2 sites. On the US side we have setup a route for the Asia traffic to get out of our firewall but we need to setup a SNAT for it to get back. We have setup an extra VLAN on the internal side for this project that we can use. The problem is that if we enable a SNAT on the external side (meaning the outgoing traffic to Asia) is SNAT'd then all traffic on the external side gets SNAT'd which breaks alot of things.
Question, is there a way to apply a SNAT to only 1 IP (the Asia IP)? or should we be using a NAT or maybe an iRule? We are scratching our heads so any help would be appreciated.
Thanks,
Kevin
  • Have u configured a snatpool?
    You can do a snatpool and specify there which are the members.
    For example:
    snatpool snat-Pool-Test {
    member 192.168.19.100 192.168.19.101
    And in each virtual server call to this snatpool like:
    virtual SNAT-example {
    destination any:any
    vlans default_1 default_2 enable
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Sure, you can create an iRule to SNAT only traffic bound for the remote server address:
    when LB_SELECTED {
       act only on connections going to remote servers
      if {[IP::addr [IP::server_addr] == 1.2.3.4]}{
         snat to local address
        snat 4.3.2.1
    HTH
    /deb
    Deb_Allen_18
    Historic F5 Account
    Better yet, if you enable SNAT automap on the selfIP on the egress vlan for that traffic, you can use "snat automap" instead:
    when LB_SELECTED {
        snat automap
        snat none
    The "snat none" action is required for non-matching traffic since automap will take effect for all traffic by default.
    /deb
  • Many thanks,
    That looks a whole lot simpler than the ideas we were coming up with. By egress VLAN, I assume you mean the VLAN the traffic came in on?
    Kevin
    Deb_Allen_18
    Historic F5 Account
    Egress VLAN would be the VLAN on which the packet leaves LTM, with the goal of forcing response traffic to return via that interface/VLAN.
    /d
