Jacob_Klein's avatar
Jacob_Klein
Jun 04, 2018
Load Balance SAP GUI with LTM
Has anyone ever built a VIP for SAP GUI in LTM? I am being asked for a VIP on port 8000 for HTTP based access and one on port 3200 for fat-client access. The trouble I am having is with identifying Send Strings for the Health Monitor to do more that simply validate a TCP socket connection.
Any thoughts, ideas, or suggestions?
  • Hi,
    First of you have to determine how you will monitor the backend. If it's a http protocol, you can firts test your monitor using curl then built it using http monitor.
    how i can help you?
    regards
