dethon_164982's avatar
dethon_164982
Jul 27, 2014
Load balance for SMPP message
Is the Message-based load balancing solution applicable for the SMPP (Short Message Point to Point) protocol ? How to define the iRules if possible. Many thanks.
  • JJMan's avatar
    JJMan
    I need the same mechanism with SMPP protocol:
    • two SMSC servers as backend:
    • If client send bind request (bind_transmitter, bind_receiver or bind_transceiver):
    . do a load balancing
    . if response is 0x00000005 (session exist), send the bind request to another backend available
    . if response is 0x00000000, make persistence to this backend node : All request from this client will be send to this node till receiving unbind request.
    . else, respond back to client with the response code.
    Do you have any idea to implement this?
    BR,
    James.
    • JJMan's avatar
      JJMan
      Hi, For MT only and without load balancing each SMS request, the default source_addr persistence profile is enough.
  • Hi,
    BR,
    James.
    • JJMan_145195's avatar
      JJMan_145195
