Load balacing syslog traffic through an LTM
My target is this:
Virtual server: syslog.example.com:6514 (would really like incoming Syslog over TLS)
Protocol: TCP
Pool: syslog-nXX.example.comf:514 (but no tls to the actual pool nodes)
From that standpoint it seems very simple to me, but I must be missing something because I have tried several different configuration paths to accomplish this but so far am seeing no traffic on the backend pool nodes.
I've searched around devecentral but if there was an answer to this it was buried in all the posts about configuring the delivery of syslog data from the f5s.
thanks
- What_Lies_Bene1
Can you expand on what you've tried please. This looks very simple (ignoring the TLS for the moment). - Greg_Swift_3395
So apparently everything i tried was in the standby node and so the reason my simple config didn't work was because it was never active.
So the basic setup:
nodes with gateway_icmp health monitor (may explore options later but syslog isn't really a 2way communication stream)
for the virtual server only thing i did was protocol tcp and the rest set to None.
Still need to figure out the SSL, but this was a great first step.
thanks and sorry. - What_Lies_Bene1
OK, so I can't be 100% sure but I presume you need to terminate SSL/TLS yes? If so you'll need a ClientSSL profile configured; is this possible or workable? - Greg_Swift_3395
Yes. I am working on the syslog configuration bits to make sure I have that nailed down then i'm going to create the client ssl profile. i'll update here when i get going - Greg_Swift_3395
So ya. Even the TLS was extremely basic. It just helps to do it on the primary system not the standby. - What_Lies_Bene1
