Alexis_Gruet_22's avatar
Alexis_Gruet_22
Sep 14, 2016
Linerate 2.6.1 / ICMP Echo
Just finished as a lab test, a basic LB scenario
1 Public IP ( 46.128.xx.xx ) as VIP --> VS --> RealServer (10.1.0.100 )
This is working however, the Public IP is not reachable through ICMP. My question is how to force ( if supported ) the public interface to be ICMP reachable ?
  • Johnny_Schmidt_'s avatar
    Johnny_Schmidt_
    Historic F5 Account
    This is a feature that prevents answering ICMP ping from hosts on different network segments. See the "LineRate Manager" docs at https://support.f5.com/kb/en-us/products/linerate/manuals/product/linerate-manager-2-6-1.html (this is a PDF download at the top of the page). Look under the section "Security" in the sub-headding "ICMP" for details.
    The short answer is, configure the LROS system to be in "gateway mode" to perform IP forwarding, which will then allow LROS to reply to ICMP ping when the source address is on a separate IP network segment (subnet) from the IP address on LROS you are attempting to ping.
  • Thanks for replying quickly!
    Yes i already read this paragraph, but i didn't found in the doc, the way to turn Linerate in gateway mode.. Please could you kindly give a short answer ?
