Frank_47355
Jan 23, 2013LED, (STA) IN AMBAR ON BLADE
We have 2 VIPRION 2400 in environemen Standalone, we have configured VCMP .
In the 2 Blades show in turn on the LED in ambar with name (STA).
I have review the logs but, there isn't any logs or alarms. var/log/ltm & var/log/messages..
Someone knows abou it.
Regards!
- pete_71470
Are you referring to the Status LED (the one just to the left of the ALM/Alarm, as seen when looking at the front of the blade)? Yellow means it's not the primary blade or the unit is Standby (seems to be your situation). - Frank_47355
of course, I´m referring the STA LED, at the front of the BLADE. I just have one Blade install in each VIRPION in the slot 1.
is normal that the LED STA be turn on in both blades.
because before it didn´t appear... :(
