kridsana_52318's avatar
kridsana_52318
Aug 03, 2017
LDAP send RST after got FIN from F5 , but if bypass F5 it's work correctly
Hi
I've problem about LDAP server send RST+ACK after F5 send FIN+ACK to LDAP server.
Is this expect behavior? because if i connect ldap server directly, LDAP server will send FIN normally (no RST+ACK like when connect via F5 virtual server)
as below picture
IP (.18.12) is LDAP server send RST+ACK after it got FIN+ACK from F5 IP (.18.85) is F5 float IP ... we do snat automap IP (.18.91) is F5 LDAP virtual server
Thank you
  • Hello kridsana,
    Based on your capture it doesn't seems that the F5 is doing something wrong because it is only forwarding your client and servers trafic.
    Could you print the config. of your VS using the following command
    list ltm virtual vs_name
    Regards
