LDAP and LDAPS load balancing question
Hello
We would like to load balance Active directory ldap and ldaps traffic via F5. I am looking through the F5 guide, can we assign SSL profile only to ldaps traffic or are able to assign different SSL profiles for ldap and ldaps?
Ldap - Plain text to clients, encrypt to LDAP servers
Ldaps End to end SSL, no decryption or bridging
Can we make LDAP and LDAPS will be accessible via a single VIP, but monitor different ports for each and set different SSL settings?
- Cory_50405
Noctilucent
You can setup two virtual servers with the same VIP, one listening on 389 and the other on 636. You'd only apply a server-side SSL profile to your 389 virtual server to encrypt the communications between the F5 and your LDAP server. No SSL profiles would need applied to your 636 virtual server as it would maintain end-to-end encryption. Same pool could be used for both virtual servers.
- Dave_C_15073
Can the F5 expose LDAPS (port 636) with an external certificate, terminate the secure connection and then establish an internal LDAPS connection using an internal certificate from the internal LDAP server?
- Lavanya_53665
Thanks. Can we use internal certificate then - Microsoft CA certificate? I am assuming yes.
- Cory_50405
Noctilucent
Yes, you can use the internal CA signed certificate for your 389 SSL server profile since it won't be presented to the connecting client.
- Greg_Crosby_319Historic F5 Account
Sounds to me like what you want to do is create 2 vips using the same ip address. One will be for ldap (ip:389), and one will be for ldaps (ip:636). Doing this will allow you to set the appropriate ssl profiles and assign the correct pool for each connection type.
- Ethen_133456
Do we need any redirection, iRule etc ? Also can I use the existing serverssl profile which I guess is the default ? Do I also need a certifictae for 636 ?
It would be helpful if someone can share the exact Process.
Thanks in Advance
- Lucian_Santos_2
LDAP e carga LDAPS balanceamentoEm LDAPS (636), deve ter um servidor de perfil SSL?Este certificado pode ser o F5 padrão?Ou você pode usar uma CA assinado servidor? - Lucian_Santos_2
In LDAPS ( 636 ) , must have a profile ssl server?
This certificate can be the standard F5 ? Or you can use a CA signed server ?
