PT2012_73791's avatar
PT2012_73791
Oct 22, 2015
LB irule and where to place in whith in an exisitng rule
Good morning all. I need help with an irule that might be better as an addition to an existing rather than a new one.
We currently have an external F5 forwarding mail requests to an internal F5. This then has 2 irules associated with it for appending, persistence and LB. The only pools configured including default pool are set within the irules.
What I need to do is add an additional pool OWA_webconsole_pool and forward any traffic with /webconsole in the HTTP Request to that pool. My issue is that I don't want to interfere with the exisiting rules and the basic rule id use has a default pool as its fall back. If I put this as a new rule last won't it negate any previous rules.
Heres what I want to do:
     if { [HTTP::uri] contains "/webconsole" } {
       pool $def_pool
but here are the 2 rules in order that already exist.
             if { ([HTTP::uri] == "/") } {
                HTTP::uri /owa
This seems to add /owa to all HTTP requests. will this overwrite any command coming in with /webconsole on the end?
 CHANGE ALL POOL NAMES TO MATCH THOSE IN YOUR ENVIRONMENT.
 YOU MIGHT CHOOSE TO USE THE SAME POOL FOR OWA, ECP and EWS.
 OAB and Autodiscover do not require persistence.
    switch -glob -- [string tolower [HTTP::path]] {
        "/microsoft-server-activesync" {
             Direct all ActiveSync clients to a common pool; use Auth
             header value if it exists (Basic auth only, which is the
             default); otherwise we fall back to client IP
            if { [HTTP::header exists "APM_session"] } {
                persist uie [HTTP::header "APM_session"] 7200
            elseif { [HTTP::header exists "Authorization"] } {
                persist uie [HTTP::header "Authorization"] 7200
            else {
                persist source_addr
            pool OwaMail_combined_vs_owa_pool
            return
        "/ews*" {
            else {
                persist cookie
            return
        "/ecp*" {
            else {
                persist cookie
            return
        "/oab*" {
            return
        "/rpc/rpcproxy.dll" {
            else {
                switch -glob [string tolower [HTTP::header "User-Agent"]] {
            "msrpc" {
            if { [HTTP::cookie exists "OutlookSession"] } {
                    persist uie [HTTP::cookie "OutlookSession"] 7200
                else {
            "*microsoft office*" {
             This section matches some versions of Outlook 2007 on Windows XP
            default {
             This section catches all other requests for Outlook
             Anywhere, and sets a persistence method that does
             not require the client to support HTTP cookies
                persist source_addr
     Finally, this assigns the Outlook Anywhere pool. If the preceding clients
     should be sent to separate pools, the pool statement should be removed
     here, and a separate pool statement placed in each of the preceding
     logic branches.
    return
    "/autodiscover*" {
     Requests for Autodiscovery information. No Persistence.
    pool OwaMail_combined_vs_ad_pool
    return
    default {
     This final section takes all traffic that has not otherwise
     been accounted for and sends it to the pool for Outlook Web App
            persist cookie
when HTTP_RESPONSE {
    if { [HTTP::header values WWW-Authenticate] contains "Negotiate" } {
        ONECONNECT::detach disable
        log local0. "OC disabled for Negotiate my_ex_single_persist"
This makes all the major LB and persistence decisions but I'm not sure where I would insert my new code to ensure that it only applied to /webconsole traffic and left everything else alone. I assume I would need to remove the pool $def_pool line.
Any advices would be hugely appreciated.
  • Simple enough, your second iRule should look like this:
             else {
                persist source_addr
             return
          "/ews*" {
             else {
                persist cookie
             return
          "/ecp*" {
             else {
                persist cookie
             return
          "/oab*" {
             return
             else {
                   "msrpc" {
                      else {
                   default {
                      persist source_addr
              logic branches.
             return
          "/autodiscover*" {
             return
          "/webconsole*" {
          default {
                persist cookie
    So webconsole is added as another label for the same switch-statement that selects all the other pools depending on the path of the URI. So the logic certainly belong in this iRule. To answer your questions - it is correct to merge this into the same iRule because it deals with the same type of decision, but even if you put it as a separate rule it wouldn't negate anything done previously unless there was a conflict between the two iRules. These iRules all handle different URI:s so there's no conflict.
    And the iRule that adds "owa" only does so when the URI is exactly "/". It probably should look for an empty URI as well but I guess the webserver will handle that.
  • Thank you, thank you. That makes sense and gives me some confidence that I was on the right track (even if I need help to see the light).
    I just had misgivings about my reasoning because obviously if it went wrong it had big implications for the whole VIP.
    I'll read it through again to make sure I understand it and then we'll see how it goes.
    Cheers
