suhail_nedaria_
Mar 15, 2017Layer 7 Persistent load balancing on MSISDN Number
Hello Friends
I have an requirement for Layer 7 persistent load balancing on "MSISDN number", particular UE traffic should come to only one server only. If the above requirement can be achieve through irule scripting then can some provide me sample config of the same.
Thanks & Regards Suhail Nedaria
- Vijay_E
Cirrus
You probably need something with UIE/Universal persistence. Alter the iRule to capture the relevant data in the incoming packet.
