Sekhar's avatar
Sekhar
Jun 21, 2017
Latency Issue - Clearing Client side connections
Hi All,
I have a general question here. If a user is experiencing latency issues, does clearing client side connections on that VIP help resolve it? Please share your thoughts on this.
Thanks,
Sekhar
  • This really depends on how busy is your device. If you are not into a high cpu usage or memory you shuld be fine. I would try to change you tcp profile settings if you are not using an advanced one. Other than that, you may need to look into you backend servers and see if there is no problem there.
