TayF5un's avatar
TayF5un
Jan 21, 2017
language problem
Hi everyone, I have web app. which is used for record some data to database. When i add some data such as name, city, country with Turkish character (ö,ğ,ü,ı,ş,ç), everything seems to be ok. However, When i make query from database, i could not display the char. correctly.
  • Thank you all, I have solved the problem which is related with app. :):)
  • TayF5un, as Niels is already requesting please explain how the BIG-IP is involved in this. If it is just load balancing (LTM) i really doubt character sets come into play, but if you are using something like ASM then things get interesting.
    so please share the setup.
  • Jie, this is related with F5, because, when client connected backend server directly everything ok.
  • JG's avatar
    JG
    This does not seem to be a question related to F5.
