IMABBAS_90_3240's avatar
IMABBAS_90_3240
Jun 12, 2017
Lab for F5 Azure or AWS
Hey Folks , i just have a small doubt in building lab for F5-Azure or AWS .Is it possible to build F5-Azure Lab environment in our own VM workstation
  • Do you have Cloud based LB Image? Azure-F5/AWS-F5 Image is store under Marketplace, So not sure how to download image file. If you have cloud-F5 image then try & let update here.
  • Yes, i dont think there is image which on vmware same like cloud.
    Thx
    Srini
