SSHSSH_97332
Apr 27, 2013L4 & L7 Connections Per Second
From F5 Hardware datasheet :
BIGIP 2000S
www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
L7 requests per second: 212K
L4 connections per second: 75K
L4 HTTP requests per second: 550K
whayt is difference between all of the above ?
- Hamish
Cirrocumulus
Different amounts of processing required. More processing requires more CPU which means fewer connections per second. Plus things that ca be accelerated don't use CPU so they get higher throughput (But tend to be simpler settings on the VS).
They're also measuring slightly different things. I think the L7 requests is requests over persistent connections (Little or no tcp 3 way handshake required). It doesn't define what sort though... L4 connections is TCP connections opened per second (3 way handshakes). While L4 HTTP requests is HTTP requests over persistent connections (Again little or no 3 way handshakes and obviously optimised so probably measuring FastHTTP profiles).
H - nitass
Employee
there is some information in the performance report just in case if you have not yet seen it.
Comparative Performance Report
http://www.f5.com/pdf/reports/F5-comparative-performance-report-ADC-2013.pdf
