Yehuda's avatar
Yehuda
Nov 12, 2019
K8s BIGIP integration error: Unable to find a flow for remote vtep
Seems that ingress from VIP never makes it into the VXLAN/VTEP...
When we curl the VIP from outside, we see thie following error in the logs:
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/log-messages.html#A01830003
01830003 : Unable to find a flow for remote vtep %A%%%u, tunnel name = %s.Location:
/var/log/ltm
Conditions:
A network virtualization tunnel (for example, VXLAN, NVGRE) is unable to find a suitable flow to send packets to a remote endpoint.
Impact:
The packets for a remote endpoint are dropped.
Recommended Action:
The recommendation is to check the configurations of a network virtualization tunnel and make sure that the corresponding tunnel FDB records are configured properly.
Has anyone ever seen this or know of a fix?
