JOURNEYS help, failed on first step.....
I've just installed JOURNEYS and I'm at the first step of the migration process where it asks for session name and description.
When I click next it prompts me with "Failed to fetch"
Can someone help me get past this?
If I understand you correctly, you haven't uploaded a UCS or connected to a live BIG-IP system; if this is the case, you need to confirm that all the containers are running properly. It'd be helpful to provide more info on how you set it up.
- Olivier_L
I had the same issue...
Not sure but the 2 commands below:
docker down
docker up -d
Seem have fixed the issue.
- Olivier_L
Now I have another issue when trying the "Discover", the SSH connection is fine but I see several:
transport Received global request "[email protected]"
transport Rejecting "[email protected]" global request from server.
And also:
config File not found, skipping
Nothing else special...
In the Journeys's logs and the GUI says:
Discovery Failed
Unexpected error
Any idea?
