Mark_Wakefield_'s avatar
Mark_Wakefield_
Nov 06, 2006
Java Compilation problems iControl v4.6.3
I downloaded the iControl SDK v4.6.3 and followed all the pre-requisite instructions, but when I go to compile the Java, I get a number of compilation errors, for the XTrustProvider class (see below). I have downloaded the v4.6.2 SDK and that compiles without error. Has anybody else come across this problem with v4.6.3, is there a fix for this?
Many thanks in advance...
Compiling GlobalLB .....
GlobalLBDataCenter.java:149: cannot find symbol
symbol : variable XTrustProvider
location: class support.SOAP.java.GlobalLB.GlobalLBDataCenter
XTrustProvider.install();
GlobalLBGlobal.java:130: cannot find symbol
location: class support.SOAP.java.GlobalLB.GlobalLBGlobal
GlobalLBStats.java:121: cannot find symbol
location: class support.SOAP.java.GlobalLB.GlobalLBStats
Note: GlobalLBDataCenter.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
3 errors
Compiling LocalLB .....
..\..\..\..\support\SOAP\java\LocalLB\XTrustProvider.java:43: duplicate class: XTrustProvider
public final class XTrustProvider extends java.security.Provider
LocalLBGlobal.java:326: cannot access support.SOAP.java.LocalLB.XTrustProvider
bad class file: ..\..\..\..\support\SOAP\java\LocalLB\XTrustProvider.java
file does not contain class support.SOAP.java.LocalLB.XTrustProvider
Please remove or make sure it appears in the correct subdirectory of the classpath.
2 errors
Compiling Management .....
..\..\..\..\support\SOAP\java\Management\XTrustProvider.java:43: duplicate class: XTrustProvider
Bigdb.java:126: cannot access support.SOAP.java.Management.XTrustProvider
bad class file: ..\..\..\..\support\SOAP\java\Management\XTrustProvider.java
file does not contain class support.SOAP.java.Management.XTrustProvider
2 errors
Compiling Networking .....
..\..\..\..\support\SOAP\java\Networking\XTrustProvider.java:43: duplicate class: XTrustProvider
Interfaces.java:145: cannot access support.SOAP.java.Networking.XTrustProvider
bad class file: ..\..\..\..\support\SOAP\java\Networking\XTrustProvider.java
file does not contain class support.SOAP.java.Networking.XTrustProvider
2 errors
Compiling System .....
..\..\..\..\support\SOAP\java\System\XTrustProvider.java:43: duplicate class: XTrustProvider
ConfigSync.java:125: cannot access support.SOAP.java.System.XTrustProvider
bad class file: ..\..\..\..\support\SOAP\java\System\XTrustProvider.java
file does not contain class support.SOAP.java.System.XTrustProvider
2 errors
