Richard__Harlan's avatar
Richard__Harlan
Historic F5 Account
Dec 01, 2011
Issuse with noyes and optional
Working on a new iApp based on f5.ip_forwarding iApp added new question that if answer yes it needs to display string text box. Could not get it working, took it to it simplest level made a new copy of the template and more one change a broke it again.
Original code
noyes forward_all
optional ( forward_all == "NO" ) {
string addr default "0.0.0.0" required validator "IpAddress"
string mask default "0.0.0.0" required validator "IpAddress"
string port default "0" required validator "PortNumber" display "small"
Changed code
noyes forward_all
optional ( forward_all == "YES" ) {
Once the code change the foward_all to yes none of the other question show up even if the option is changed. Now it get weirder if I change it back to NO it still does not work till I create a new Template. Has anyone see this and have a work around to get this working? Thanks
  • Brent_Blood_768's avatar
    Brent_Blood_768
    Historic F5 Account
    Hey Richard,
    Quick check: try changing the "YES" to "Yes" (and "NO" to "No") as the value of YES_ANSWER is "Yes" - and I'm pretty sure case matters for the expressions entered in optional elements.
    "noyes" is defined in an apl script library as the following:
    define choice noyes default "No" display "small" {"No", "Yes"}
    Cheers,
    -Brent
