alex_talmage_28's avatar
alex_talmage_28
Sep 01, 2017
Issues with Portal-Access via Webtop when using DNS name
Hi All,
I'm having some issues getting a Portal-Access link to work.
I'm using APM, have a webtop working, but when I click any portal-access links that I've set up that direct to internal resources, I receive a 400 Bad Request. This is if I browse to the APM using its externally resolvable DNS name.
If I browse to the webtop via its public Ip address and do the same, the portal-access links work!
Hopefully this is a simple one, any ideas?
  • Hello Alex
    Could you share a screenshot of your Portal-Access configuration in "Advanced Mode"
    Maybe you used wrong "Link Type" and "Application URI" settings...
    Regards
