Issue with SNAT
Hello, I have configured VIP with specific SNAT. snat IP is other than the LAN subnet. VIP works with AUTOMAP, however when specific SNAT configure is do not work,
below is the config of VIP.
virtual r_vs_agr {
snat automap
pool Pool_AGR
destination 10.155.65.39:https
ip protocol tcp
persist persist_sso
profiles {
http_sso {}
r_clientssl_uat-sso {
clientside
serverssl {
serverside
tcp {
clientside
tcp-lan-optimized {
serverside
vlans INTERCO enable
pool Pool_AGR {
lb method member observed
monitor all my_http_GET and tcp_halfopen_8446
members {
10.155.51.29:8446 {}
10.155.51.30:8446 {}
10.155.51.53:https {}
10.155.51.54:https {}
When I configure SNAT with an IP of 10.155.70.x range VIP becomes non accessible.
I also checked on pool nodes for route and found default route pointing to my core switches from which SNAT IP is accessible with source IP.
I dont understand, why it is not working with specific SNAT if it works with AUTOMAP. which IP VIP takes to communicate with nodes if automap is configured for VIP?
Regards,
Kalpesh
- What_Lies_Bene1
Automap will use the floating Self IP of the VLAN used to communicate with the Pool Members.
What configuration are you using when you assign a specific SNAT IP? Can you post that too?
Regarding routing, are you sure the return traffic is being routed back to the F5 when you use the specific IP? That's normally where the issue lies. Without understanding the VLAN and routing infrastructure further it's hard to comment more. - Kalpesh_48932
SNAT is 10.155.70.144.
I checked trace for this IP from server and found traffic pointing correctly to core switches..but then its not going to F5
[cas@A92SV00498AGR ~]$ traceroute 10.155.48.84 -p 443
traceroute to 10.155.48.84 (10.155.48.84), 30 hops max, 40 byte packets
1 10.155.51.2 (10.155.51.2) 1.046 ms 1.023 ms 1.008 ms
2 10.155.48.84 (10.155.48.84) 0.665 ms 0.653 ms 0.601 ms
[cas@A92SV00498AGR ~]$ traceroute 10.155.70.144 -p 443
traceroute to 10.155.70.144 (10.155.70.144), 30 hops max, 40 byte packets
1 10.155.51.3 (10.155.51.3) 0.841 ms 0.813 ms 0.798 ms
2 * * *
I have route on core switches for SNAT IP
ip route 10.155.70.144/32 10.155.48.84
10.155.70.144/32, ubest/mbest: 1/0
*via 10.155.48.84, Vlan234, [1/0], 3w4d, static
Still it do not work - What_Lies_Bene1
And is 10.155.48.84 a floating Self IP on the F5, on VLAN234? - nitass
Employee
2 * * * why is the first hop different (10.155.51.2 and 10.155.51.3)? - Kalpesh_48932
@Steve
"And is 10.155.48.84 a floating Self IP on the F5, on VLAN234?"
Yes..
@Nitass
Its OK..I have route on both the core server for SNAT IP..even if packet goes on 10.155.51.2 it is unreachable.
[cas@A92SV00499AGR ~]$ traceroute -p 443 10.155.70.144
1 10.155.51.2 (10.155.51.2) 2.223 ms 2.194 ms 2.180 ms
2 * * * - nitass
Employee
When I configure SNAT with an IP of 10.155.70.x range VIP becomes non accessible.how did you configure the snat? would you mind posting the snat configuration you used? - What_Lies_Bene1
@Nitass, I assume the first hop difference is just a HSRP thing. - Kalpesh_48932
@Nitass..right now i have kept snat as automap..and i have configured snat in snat pool list...and from there i am calling it in VIP.
I tried with commandline to get config of snat but it gives me error as no such snat configured. - nitass
Employee
i have configured snat in snat pool list...and from there i am calling it in VIP.that should be correct already.
do you remember when using snatpool, can you ping snatpool ip from server?
when you test it again, would you mind also running tcpdump on bigip to see what is going on?
e.g.
tcpdump -nni 0.0 -s0 host 10.155.65.39 or host 10.155.70.144
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host 10.155.65.39 or host 10.155.70.144 - Kalpesh_48932
Can you please confirm me command to verify snat config..
i tried
bigpipe snat
no result. it may be because..i have not assigned this snat to any VIP.
