ISSUE WITH PERSISTENCE ON GTM
Hi All,
I have a setup as below:
GTM wideip - Pool 1 - Pool 1 has two members which are VIPs on different LTMs.
On wideip pool LB mode is RR and within the pool LB mode is RR.
Behind each VIP have one server. On the VIPs persistence method is SRC IP
Persitence is configured on GTM for 3600 seconds and on LTM VIPs as 1800 seconds.
Issue observed: 1) Even after persistence value expires on GTM, the request is going to the same pool member 2) I dont see any persistence records created on the LTM.
GTM is 10.2.0 HF2 and LTMs are 10.2.4 HF3.
Is there something that i am missing here?? Please advise.
- How DNS is resolved. PC -> LDNS -> GTM or PC -> GTM
- I would check settings for TTL too.
- What is the status for member1 are they up.
- Prince
Altostratus
Hello Dev,
Its PC->LDNS->GTM The members are up. Even after the persistence TTL expires I the resolution is same.
