Issue with iRule adding secure cookie flag
I am using the common iRule for setting the secure cookie flag on each cookie-
when HTTP_RESPONSE {
set cookies [HTTP::cookie names]
Loop through each cookie by name in request
foreach aCookie $cookies {
Replace cookie name from list and set Secure Flag to Enable
HTTP::cookie secure $aCookie enable
The issue comes up when there is a cookie whose data has a space in it. The iRule appears to truncate the cookie at the space.
cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR
Any thoughts on how to met the iRule to process this cookie correctly?
Thanks-
Mike
- mjbeadle
Well, it looks like the space breaks it reading the cookie. I changed the irule to log the cookie instead of add the flag and I see a cookie with name Services&SPONSOR (the text after the space. Is there any way to work around this on the F5 or will it have to be a change in the site?
Mike - Kevin_Stewart
Employee
If you add in some logging, what do you see?when HTTP_RESPONSE { set cookies [HTTP::cookie names] Loop through each cookie by name in request foreach aCookie $cookies { log local0. "$aCookie = [HTTP::cookie value $aCookie]" Replace cookie name from list and set Secure Flag to Enable HTTP::cookie secure $aCookie enable } }
What F5 version are you on? - nitass
Employee
The issue comes up when there is a cookie whose data has a space in it. i thought cookie value does not contain whitespace.
HTTP cookie
http://en.wikipedia.org/wiki/HTTP_cookie
anyway, it seems okay to me here.
e.g.[root@ve10:Active] config b version|grep -iA 1 version BIG-IP Version 10.2.4 655.0 Hotfix HF4 Edition [root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.252:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b pool foo list pool foo { members 200.200.200.101:80 {} } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_RESPONSE { set cookies [HTTP::cookie names] foreach aCookie $cookies { log local0. "$aCookie = [HTTP::cookie value $aCookie]" HTTP::cookie secure $aCookie enable } } } log [root@ve10:Active] config cat /var/log/ltm Jul 22 17:29:54 local/tmm info tmm[26228]: Rule myrule : cookie = CGI&SPONSOR_UserRole=Information Services&SPONSOR trace [root@ve10:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.20.17(47282) <-> 172.28.19.252(80) 1374485394.6293 (0.0010) C>S --------------------------------------------------------------- HEAD / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 172.28.19.252 Accept: */* --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(47282) <-> 200.200.200.101(80) 1374485394.6321 (0.0010) C>S --------------------------------------------------------------- HEAD / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 172.28.19.252 Accept: */* --------------------------------------------------------------- 1374485394.6353 (0.0031) S>C --------------------------------------------------------------- HTTP/1.1 200 OK Date: Mon, 22 Jul 2013 09:40:26 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Thu, 23 May 2013 00:28:46 GMT ETag: "4185a8-59-c3efab80" Accept-Ranges: bytes Content-Length: 89 Set-Cookie: cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR Connection: close Content-Type: text/html; charset=UTF-8 --------------------------------------------------------------- 1374485394.6354 (0.0060) S>C --------------------------------------------------------------- HTTP/1.1 200 OK Date: Mon, 22 Jul 2013 09:40:26 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Thu, 23 May 2013 00:28:46 GMT ETag: "4185a8-59-c3efab80" Accept-Ranges: bytes Content-Length: 89 Set-Cookie: cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR;secure; Connection: close Content-Type: text/html; charset=UTF-8 --------------------------------------------------------------- - mjbeadle
Running 11.3.0.
I did add some logging and found that it was show a cookie with the name containing the text after the space in the first cookie.
- mjbeadle
With the string you are using to test add = to the string, so it would look something like
SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC
Mike
- nitass
Employee
i think the correct way is to fix cookie value at server.
anyway, if there is small number of cookie value containing space, you may temporarily remove (space) and add it back after securing cookie.
e.g.root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar15 ltm virtual bar15 { destination 172.28.20.15:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { myrule } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } } } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when HTTP_RESPONSE { remove space set cklist [HTTP::header values Set-Cookie] HTTP::header remove Set-Cookie foreach ck $cklist { HTTP::header insert Set-Cookie [string map {"Information Services" "InformationServices"} $ck] } secure cookie foreach aCookie [HTTP::cookie names] { HTTP::cookie secure $aCookie enable } add space set cklist [HTTP::header values Set-Cookie] HTTP::header remove Set-Cookie foreach ck $cklist { HTTP::header insert Set-Cookie [string map {"InformationServices" "Information Services"} $ck] } } } original response [root@ve11a:Active:Changes Pending] config curl -I http://200.200.200.101 HTTP/1.1 200 OK Date: Mon, 22 Jul 2013 14:06:26 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Thu, 23 May 2013 00:28:46 GMT ETag: "4185a8-59-c3efab80" Accept-Ranges: bytes Content-Length: 89 Set-Cookie: SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC Set-Cookie: EPowerV4Users=carrefourvoyagesb2b=13_user; path=/; secure Connection: close Content-Type: text/html; charset=UTF-8 response after passing bigip [root@ve11a:Active:Changes Pending] config curl -I http://172.28.20.15 HTTP/1.1 200 OK Date: Mon, 22 Jul 2013 14:06:35 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Thu, 23 May 2013 00:28:46 GMT ETag: "4185a8-59-c3efab80" Accept-Ranges: bytes Content-Length: 89 Connection: close Content-Type: text/html; charset=UTF-8 Set-Cookie: SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC;secure; Set-Cookie: EPowerV4Users=carrefourvoyagesb2b=13_user; path=/; secure
