Vitaliy_Savrans's avatar
Dec 06, 2013
issue with health monitor instances
Using templates I have created health monitor for checking dns servers. The value for the Alias Address setting in the monitor is set to the wildcard * Addresses. This monitor is applied to the pool which has 2 members, but in the Local Traffic >> Monitors >> My monitor >> Instances there is only one member. Am I doing something wrong and how can I apply it to all pool members? (Running on v 11.3.0 HF8).
  • The Alias Address and port is used for transparent monitors - where LTM checks an external address through a device such as a proxy or gateway. If you have applied the monitor to the pool then LTM will send that monitor to the ip address and port for that pool member. If you apply the monitor to the node then it will send the monitor only to that node.
    You should apply the icmp monitor at the node level as the default node monitor and assign the DNS monitor at the pool level.
  • Pete, I assigned DNS monitor at the pool level, but in instances i see only one pool member (pool has 2 members) is it ok? How the second member will be checked?
  • If you have assigned the monitor to the pool then there should be all members in the Instances page. Check at which level you have the monitor assigned and that it isn't at the node level. Feel free to send the output of "tmsh list ltm pool" and "tmsh list ltm node".
  • My output:
     ltm pool ns {
    members {
        10.10.10.17:domain {
            address 10.10.10.17
            monitor udp
            session monitor-enabled
            state up
        10.10.10.18:domain {
            address 10.10.10.17
            state up
    monitor dns_health_monitor
    ltm node 10.10.10.17 {
    address 10.10.10.17
    description host_10.10.10.17
    monitor none
    ltm node 10.10.10.18 {
    address 10.10.10.18
    description host_10.10.10.18
    monitor none
  • You have defined specific member monitor on 10.10.10.17 member.
    So it erases the default monitor dns_health_monitor.
    I think there's only member 10.10.10.18 in your Instances monitor, isn't it ?
  • Yes, it was enabled udp monitor on member 10.10.10.17, that why I see only 10.10.10.18 in instances. Pete, Thomas thanks for your help.
